[petsc-dev] PETSc goes Doxygen!?
Karl Rupp
rupp at mcs.anl.gov
Tue Jan 15 16:36:45 CST 2013
Hi Matt,
> Right now, the search stinks. If I type in
> GetCone
> I get nothing found, whereas
> DMPlexGetCone
> has three things found, but does not find DMPlexSetCone. This is crappy,
> and will
> not replace seeing everything on one page, which I miss.
Well, you can't expect the search engine to find DMPlexSetCone if you
search for DMPlexGetCone ;-) Either of the two is correctly
cross-referenced at the other's man page, though.
There is also a server-side driven search engine (off by default), maybe
that one will also find results for 'GetCone'.
Regardless, listing all functions of a class for the various levels on
one page is something I can fairly easily add if we finally decide to
keep Doxygen.
Best regards,
Karli
