[petsc-dev] multiple dispatch code currently in PETSc
Dmitry Karpeev
karpeev at mcs.anl.gov
Tue Jan 15 15:29:00 CST 2013
On Tue, Jan 15, 2013 at 3:20 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Jan 15, 2013 at 3:14 PM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>> There is, by the way, the 'type' field in the header, which the docs say
>> should no longer be used, and which is typically set to 0 or -1 in calls to
>> PetscHeaderCreate. So, barring some subtle backward-compatibility issue
>> this can be reused to hold the typeid, which is computed or looked up on
>> each PetscObjectChangeTypeName()?
> The usual way to do this would be to make the classid field be either a
> pointer or an index into a global petsc_classes data structure. I recently
> set up that infrastructure for Fortran pointers, but that class object
> could be used for multiple dispatch as well.
I'll try to take a look at this over the weekend.
Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130115/1621ffc2/attachment.html>
