[petsc-dev] Coding style and its violations...
Karl Rupp
rupp at mcs.anl.gov
Tue Jan 15 14:42:58 CST 2013
Dear all,
quoting a recent commit:
> BarryFSmith committed 16 hours ago (raw commit)
> silly code formatting problems; some people still need to read the
> style guide
So we have a style guide that is partially respected, partially ignored.
Some things are pretty hard to check automatically, while others are
rather simple. So let's pick
"No tabs are allowed in any of the source code."
as an example and run
$petsc-dev/src> find . -name *.h -type f | xargs grep -P '\t' | wc -l
to pick the number of violations in .h-files. I get 3215 hits, which is
still small compared to the 8797 hits in .c-files.
So, what can we do to reduce the number of violations of the style guide
and keep the number of violations as small as possible in the future?
- First and foremost, eliminate (as many of the) existing violations (as
possible) and come to a clean state.
- Run pre-push-scripts on bitbucket on the diff. They may not find all
violations, but at least check for the most obvious ones.
- Add nightly tests on the source tree. We can compare the output of a
properly configured uncrustify against the existing source files and
complain on a mismatch.
Unless there are objections, I'm willing to devote some time on that
while playing with options for a better testing environment. I don't
think that a full elimination of all violations is ever possible nor
reasonably attainable. However, a reduction of violations simplifies the
handling of the code base considerably and is thus worth the effort.
Best regards,
Karli
