[petsc-dev] multiple dispatch code currently in PETSc
Jed Brown
jedbrown at mcs.anl.gov
Tue Jan 15 14:14:40 CST 2013
On Tue, Jan 15, 2013 at 1:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Do we really want mallocs for EVERY single multiple-dispatch function
> call in PETSc? I suggest not having MatQueryOp() but calling directly
> PetscOpFListFind() (with the MatOpFList argument) and changing
> PetscOpFListAdd/Find() to use variable args directly.
> Finally do we really want string comparisons at all here? Or do we want
> XXXRegister() (for example, MatRegister()) to compute an integer type id to
> go with each char *type_name and do the search off the integer type id
> instead of strings? Thus making PetscOpFListFind() super light weight?
static struct {
PetscMultiDispatch ptap;
} MatMultiDispatch;
I would have
PetscMultiDispatchRegister("MatPtAP",2,&MatMultiDispatch.ptap), then
PetscMultiDispatchFind(MatMultiDispatch.ptap,(PetscObject)A,(PetscObject)P,&ptapfunc);
I think passing PetscObject is natural here, in which case using
obj->type_id instead of obj->type_name can be done later. But on that
front, yes, I think making integers for all registered type_names would be
good. Among other things, it would make the PetscObjectTypeCompares fast,
although I think those places should eventually be refactored.
> Barry
> PetscErrorCode MatQueryOp(MPI_Comm comm, PetscVoidFunction* function,
> const char op[], PetscInt numArgs, ...)
> PetscErrorCode ierr;
> va_list ap;
> PetscInt i;
> const char *argType;
> char **argTypes = PETSC_NULL;
> PetscFunctionBegin;
> va_start(ap,numArgs);
> if (numArgs) {
> ierr = PetscMalloc(sizeof(char*)*numArgs, &argTypes);CHKERRQ(ierr);
> for (i = 0; i < numArgs; ++i) {
> argType = va_arg(ap,const char*);
> ierr = PetscStrallocpy(argType, argTypes+i);CHKERRQ(ierr);
> va_end(ap);
> ierr = PetscOpFListFind(comm, MatOpList, function, op, numArgs,
> ierr = PetscFree(argTypes[i]);CHKERRQ(ierr);
> ierr = PetscFree(argTypes);CHKERRQ(ierr);
> PetscFunctionReturn(0);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130115/050944dc/attachment.html>
