[petsc-dev] multiple dispatch code currently in PETSc
Matthew Knepley
knepley at gmail.com
Tue Jan 15 14:06:38 CST 2013
On Tue, Jan 15, 2013 at 1:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Do we really want mallocs for EVERY single multiple-dispatch function
> call in PETSc? I suggest not having MatQueryOp() but calling directly
> PetscOpFListFind() (with the MatOpFList argument) and changing
> PetscOpFListAdd/Find() to use variable args directly.
I am fine with that.
> Finally do we really want string comparisons at all here? Or do we want
> XXXRegister() (for example, MatRegister()) to compute an integer type id to
> go with each char *type_name and do the search off the integer type id
> instead of strings? Thus making PetscOpFListFind() super light weight?
Not unless you have a way to lookup the integer from the string. Some
people might only have the string.
Matt
> Barry
> PetscErrorCode MatQueryOp(MPI_Comm comm, PetscVoidFunction* function,
> const char op[], PetscInt numArgs, ...)
> PetscErrorCode ierr;
> va_list ap;
> PetscInt i;
> const char *argType;
> char **argTypes = PETSC_NULL;
> PetscFunctionBegin;
> va_start(ap,numArgs);
> if (numArgs) {
> ierr = PetscMalloc(sizeof(char*)*numArgs, &argTypes);CHKERRQ(ierr);
> for (i = 0; i < numArgs; ++i) {
> argType = va_arg(ap,const char*);
> ierr = PetscStrallocpy(argType, argTypes+i);CHKERRQ(ierr);
> va_end(ap);
> ierr = PetscOpFListFind(comm, MatOpList, function, op, numArgs,
> ierr = PetscFree(argTypes[i]);CHKERRQ(ierr);
> ierr = PetscFree(argTypes);CHKERRQ(ierr);
> PetscFunctionReturn(0);
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130115/f1ee543e/attachment.html>
