[petsc-dev] Counting Fortran function pointers
Jed Brown
jedbrown at mcs.anl.gov
Thu Jan 10 18:31:57 CST 2013
There is still a bit of grunt work left.
$ grep AllocateFortran src/**/*.c
src/dm/impls/shell/ftn-custom/zdmshellf.c:
PetscObjectAllocateFortranPointers(*dm,2);
src/ksp/pc/impls/mg/ftn-custom/zmgfuncf.c:
PetscObjectAllocateFortranPointers(*mat,1);
src/ksp/pc/impls/shell/ftn-custom/zshellpcf.c:
PetscObjectAllocateFortranPointers(*pc,5);
src/mat/impls/mffd/ftn-custom/zmffdf.c:
PetscObjectAllocateFortranPointers(*mat,2);
src/mat/impls/shell/ftn-custom/zshellf.c:
PetscObjectAllocateFortranPointers(*mat,11);
src/mat/interface/ftn-custom/zmatrixf.c:
PetscObjectAllocateFortranPointers(*sp,1);
src/snes/linesearch/impls/shell/ftn-custom/zlinesearchshellf.c:
PetscObjectAllocateFortranPointers(*linesearch,3);
src/snes/linesearch/interface/ftn-custom/zlinesearchf.c:
src/sys/classes/draw/utils/ftn-custom/zzoomf.c:
PetscObjectAllocateFortranPointers(*draw,1);
src/ts/interface/ftn-custom/ztsf.c:
PetscObjectAllocateFortranPointers(*ts,OUR_COUNT);
On Thu, Jan 10, 2013 at 6:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> You had a problem with this? :-) Some dusty old corners of PETSc are
> best never viewed.
> -snes->fortran_func_pointers usage:
> -0: oursnesfunction
> -1: oursnestest
> -2: oursnesjacobian
> -3: oursnesmonitor
> -4: oursnesmonitor ctx
> -5: ourmondestroy
> -6: unused
> -7: unused
> -8: unused
> -9: unused
> -10: ourdestroy
> -11: oursnestest ctx
> -12: unused
> -13: oursnesgs
> On Jan 9, 2013, at 7:37 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Richard, I pushed a new Fortran callback handling system. It is
> subtype-safe and doesn't rely on crazy static numbering. You can see what
> is left to do by
> > Once these are gone, we can delete the old system.
> > Meanwhile, you can add new functions using the system here. The Set call
> will create a callback ID if it doesn't exist yet and the object will
> automatically handle resizing and resetting when you change subtypes.
> https://bitbucket.org/petsc/petsc-dev/commits/f2a68b8a037edffd463d1ee6e9014e2edcd4aad7
> > a couple more instances:
> https://bitbucket.org/petsc/petsc-dev/commits/bc94ac15bf5a75c3290770efe7e624a46ddcad37
> > On Mon, Jan 7, 2013 at 5:48 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Richard, it's better to mail the list. No, we haven't reworked subtype
> Fortran pointers yet, but I think we know what needs to be done.
> > On Mon, Jan 7, 2013 at 1:42 PM, Richard Tran Mills <rtm at eecs.utk.edu>
> wrote:
> > Hi Jed,
> > I am back at work after some extended time away and I need to start
> messing with DMShell so that I can use it to set operations like
> LocalToGlobal and GlobalToLocal updates from inside PFLOTRAN.
> > Did this issue of handling the Fortran function pointers get resolved
> somehow? Is there something I need to change in how I am doing the Fortran
> bindings?
> > Cheers,
> > Richard
> > On 12/4/12 5:43 PM, Jed Brown wrote:
> >> As usual, anything that is duplicated and not checked by the compiler
> is broken.
> >> $ grep PetscObjectAllocateFortranPointers src/**/*.c
> >> src/dm/impls/da/ftn-custom/zda2f.c:
> PetscObjectAllocateFortranPointers(*da,6);
> >> Note that changing the type does not reset the function pointers, thus
> having a DMSHELL, calling DMSetType(dm,DMDA), and then setting a DMDA local
> function will cause memory corruption.
> >> I cannot express how much I hate this system. The full-blown solution
> is that for each type, we register a (global) token which is the index of
> that function pointer. That doesn't have any false dependencies, but is
> more "initialize" code.
> >> An alternative, used in the TS and KSP code below, is to have a common
> enum that lists all the Fortran functions. It's a false header dependency,
> but not a binary dependency.
> >> What should we do? The current state is a disaster.
> >> src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.c:
> PetscObjectAllocateFortranPointers(*ksp,3);
> >> src/ksp/ksp/interface/ftn-custom/zitfuncf.c:
> PetscObjectAllocateFortranPointers(*ksp,FTN_MAX);
> >> src/snes/interface/ftn-custom/zsnesf.c:
> PetscObjectAllocateFortranPointers(*snes,14);
> >> src/sys/draw/utils/ftn-custom/zzoomf.c:
> > Richard Tran Mills, Ph.D.
> > Computational Earth Scientist | Joint Assistant Professor
> > Hydrogeochemical Dynamics Team | EECS and Earth & Planetary Sciences
> > Oak Ridge National Laboratory | University of Tennessee, Knoxville
> > E-mail:
> > rmills at ornl.gov V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130110/f9ae61b6/attachment.html>
