[petsc-dev] Access Non-Local Data in Function routine and Jacobian	routine
    Hesameddin Ilatikhameneh
    hilatikh at purdue.edu
    Thu Jan 10 13:58:16 CST 2013
Hello,
I'm trying to use Petsc Non-linear solver such that in Function routine I have access to the variables on the other cpus.
As far as I know, the Function and Jacobian routine gives the solution vectors as input "Locally". So when I use:
  /* Get pointers to vector data */
  ierr = VecGetArray(X,&x); CHKERRQ(ierr);
  ierr = VecGetArray(G,&g); CHKERRQ(ierr)
I will have just access to local data.
I tried to create a ghost vector using my local data container (VecCreateGhostWithArray(...,&Local_Data)) and hoped that Petsc would change the data in data container and each time that Function routine or Hessian routine be called I can use my ghost vector to access the non-local data. However, it seems that Local_Data container do not update despite I used "WithArray" and assemble each time.
Thanks
Hesam
