[petsc-dev] [mpich-discuss] MPICH migration to git
Dmitry Karpeev
karpeev at mcs.anl.gov
Wed Jan 9 22:03:13 CST 2013
On Jan 9, 2013 9:51 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
> On Jan 9, 2013, at 7:17 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Libmesh just moved to github as well.
> > I think if you carefully consider the branching model, it has a clear
advantage over everything else. Dusty Phillips put it nicely in his recent
blog post [1]:
> > Git branches are simple and elegant. Mercurial branches are… well, it
depends what kind of branch you want. You do know what kind of branch you
want, right?
> Branches are the work of the devil and should be avoided at all cost
> > Fortunately, his project "gitifyhg" is now usable. [2]
> > As for consensus shifting towards git, I know only a few people that
have used both seriously and still prefer Hg. Meanwhile, there are a ton of
serious Python folks that prefer git (Lisandro, Andy Terrel, SciPy, NumPy,
PyClaw, etc).
> > [1]
http://archlinux.me/dusty/2012/12/18/four-ways-to-do-local-lightweight-git-style-branches-in-mercurial/
> > [2] http://archlinux.me/dusty/2013/01/06/gitifyhg-rewritten/
> 1) If Satish and you can come up with (or point me to) a mapping from
my current hg workflow (which is pretty dang simple-minded) to how I would
do things correctly in Git (and I am satisfied with that mapping) and
> 2) There is a way to translate our current hg repository to git without
losing information and
> 3) We can continue to use bitbucket more or less that same way as now
(or is there a reason to shift to github and it has decent "project"
support?)?
> Then I would consider switching over to git and proceeding to make fun
of hg users,
Is this the only reason to switch? Since otherwise it would have to be
equivalent to hg (as per your aforementioned requirements). Besides,
currently there is no globally-visible use of branches in the petsc
workflow, as far as I can tell. Finally, you would have to deal with the
INDEX and the extra states that it implies.
Dmitry
> Barry
> > On Wed, Jan 9, 2013 at 5:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Yes but given their absolutely horrible decision to stick with SVN
all these years I cannot trust their decision to go with GIT. Sadly this is
a very big argument for NOT switching PETSc to GIT. This email is only
partly in jest, it has a serious component as well: is the "everyone's
switching to git" just a case of the sheeple following the latest new thing
without a proper technical evaluation or is it a carefully thought out
decision?
> > Barry
> > On Jan 8, 2013, at 6:38 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > > Everyone's doing it. ;-)
> > > ---------- Forwarded message ----------
> > > From: Dave Goodell <goodell at mcs.anl.gov>
> > > Date: Tue, Jan 8, 2013 at 6:23 PM
> > > Subject: [mpich-discuss] MPICH migration to git
> > > To: discuss at mpich.org
> > > MPICH users & developers,
> > > The MPICH project has transitioned from using SVN as our version
control system (VCS) to using git instead. Details of the switch are
described here:
> > > http://wiki.mpich.org/mpich/index.php/Git
> > > Highlights from the document and the transition:
> > > * Read-only git clones are available at http://git.mpich.org/mpich.gitand git://
> > > * All critical history from SVN has been imported into the git
history.
> > > * The SVN server and its associated history are not going away,
although it has been made read-only.
> > > We continue to work through our documentation and automated processes
(cron jobs, etc.) to update them to the new system. Our trac instance will
transition to understand the new VCS soon, although it currently displays
only historical SVN data.
> > > Please bear with us as we work through this transition period. If
you have trouble with the new setup, please contact devel at mpich.org or
discuss at mpich.org for assistance.
> > > Regards,
> > > The MPICH Team
> > > _______________________________________________
> > > discuss mailing list discuss at mpich.org
> > > To manage subscription options or unsubscribe:
> > > https://lists.mpich.org/mailman/listinfo/discuss
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130109/516918f1/attachment.html>
