[petsc-dev] [mpich-discuss] MPICH migration to git
Jed Brown
jedbrown at mcs.anl.gov
Wed Jan 9 22:01:06 CST 2013
I'll set up a git mirror (probably this weekend) so we can compare workflow.
On Wed, Jan 9, 2013 at 9:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jan 9, 2013, at 7:17 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Libmesh just moved to github as well.
> > I think if you carefully consider the branching model, it has a clear
> advantage over everything else. Dusty Phillips put it nicely in his recent
> blog post [1]:
> > Git branches are simple and elegant. Mercurial branches are… well, it
> depends what kind of branch you want. You do know what kind of branch you
> want, right?
> Branches are the work of the devil and should be avoided at all cost :-)
> > Fortunately, his project "gitifyhg" is now usable. [2]
> > As for consensus shifting towards git, I know only a few people that
> have used both seriously and still prefer Hg. Meanwhile, there are a ton of
> serious Python folks that prefer git (Lisandro, Andy Terrel, SciPy, NumPy,
> PyClaw, etc).
> > [1]
> http://archlinux.me/dusty/2012/12/18/four-ways-to-do-local-lightweight-git-style-branches-in-mercurial/
> > [2] http://archlinux.me/dusty/2013/01/06/gitifyhg-rewritten/
> 1) If Satish and you can come up with (or point me to) a mapping from my
> current hg workflow (which is pretty dang simple-minded) to how I would do
> things correctly in Git (and I am satisfied with that mapping) and
> 2) There is a way to translate our current hg repository to git without
> losing information and
> 3) We can continue to use bitbucket more or less that same way as now (or
> is there a reason to shift to github and it has decent "project" support?)?
> Then I would consider switching over to git and proceeding to make fun of
> hg users,
> Barry
> > On Wed, Jan 9, 2013 at 5:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Yes but given their absolutely horrible decision to stick with SVN all
> these years I cannot trust their decision to go with GIT. Sadly this is a
> very big argument for NOT switching PETSc to GIT. This email is only partly
> in jest, it has a serious component as well: is the "everyone's switching
> to git" just a case of the sheeple following the latest new thing without a
> proper technical evaluation or is it a carefully thought out decision?
> > Barry
> > On Jan 8, 2013, at 6:38 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > > Everyone's doing it. ;-)
> > > ---------- Forwarded message ----------
> > > From: Dave Goodell <goodell at mcs.anl.gov>
> > > Date: Tue, Jan 8, 2013 at 6:23 PM
> > > Subject: [mpich-discuss] MPICH migration to git
> > > To: discuss at mpich.org
> > > MPICH users & developers,
> > > The MPICH project has transitioned from using SVN as our version
> control system (VCS) to using git instead. Details of the switch are
> described here:
> > > http://wiki.mpich.org/mpich/index.php/Git
> > > Highlights from the document and the transition:
> > > * Read-only git clones are available at http://git.mpich.org/mpich.gitand git://
> > > * All critical history from SVN has been imported into the git history.
> > > * The SVN server and its associated history are not going away,
> although it has been made read-only.
> > > We continue to work through our documentation and automated processes
> (cron jobs, etc.) to update them to the new system. Our trac instance will
> transition to understand the new VCS soon, although it currently displays
> only historical SVN data.
> > > Please bear with us as we work through this transition period. If you
> have trouble with the new setup, please contact devel at mpich.org or
> discuss at mpich.org for assistance.
> > > Regards,
> > > The MPICH Team
> > > _______________________________________________
> > > discuss mailing list discuss at mpich.org
> > > To manage subscription options or unsubscribe:
> > > https://lists.mpich.org/mailman/listinfo/discuss
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130109/47893323/attachment.html>
