[petsc-dev] Documentation comment support
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Jan  8 21:34:44 CST 2013
On Tue, Jan 8, 2013 at 9:32 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Jan 8, 2013 at 8:45 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
>> I was thinking of using an input filter, perhaps after creating an index.
>>> http://www.stack.nl/~dimitri/**doxygen/manual/config.html#**
>>> cfg_input_filter<http://www.stack.nl/~dimitri/doxygen/manual/config.html#cfg_input_filter>
>> If a single filter is sufficient for all files, this is indeed the better
>> option. Thanks.
> We get the file name in argv[1] so it can use the path to do different
> things. For example, examples/tests/ are treated differently from
> examples/tutorials/, which are different from library code.
To improve Fortran stubs, I've considered going so far as to get a proper
parse, e.g., with pycparser.
https://bitbucket.org/eliben/pycparser
I don't think you need anything this sophisticated to augment the
documentation, but I don't think there is any loss of generality from using
an input filter.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130108/703c4ff9/attachment.html>
