[petsc-dev] Documentation comment support
Jed Brown
jedbrown at mcs.anl.gov
Tue Jan 8 21:32:21 CST 2013
On Tue, Jan 8, 2013 at 8:45 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> I was thinking of using an input filter, perhaps after creating an index.
>> http://www.stack.nl/~dimitri/**doxygen/manual/config.html#**
>> cfg_input_filter<http://www.stack.nl/~dimitri/doxygen/manual/config.html#cfg_input_filter>
> If a single filter is sufficient for all files, this is indeed the better
> option. Thanks.
We get the file name in argv[1] so it can use the path to do different
things. For example, examples/tests/ are treated differently from
examples/tutorials/, which are different from library code.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130108/60085663/attachment.html>
