[petsc-dev] patch for BiCG on GPUs.
Jed Brown
jedbrown at mcs.anl.gov
Fri Jan 4 19:28:41 CST 2013
Sorry about the slow reply. Yes, petsc-dev is a good place for this. I have
a couple comments. First, it's *much* better to split the "organization"
part of the patch (which should be benign) from the new functionality.
Small independent patches are so much easier to evaluate than monolithic
patches. When in doubt, split them apart.
- CUSPARRAY *xarray,*yarray;
+ CUSPARRAY *xarray,*yarray=PETSC_NULL;
This is a very bad method for squashing warnings because it prevents
valgrind and static analysis from checking for uninitialized access. It's
much better to go to the routine that initializes yarray and have it
initialize explicitly at the start. This fixes the warnings in all the
cases I've encountered. (Hopefully this bug, in which the compiler
sometimes does not figure out that that a return value is checked so that a
variable is never used uninitialized, will eventually be fixed so this
problem goes away.)
+ else {
The PETSc developer's manual says to use '} else {' instead.
+PetscErrorCode MatSeqAIJCUSPARSEAnalyzeTransposeForSolve(Mat A)
+ Mat_SeqAIJCUSPARSETriFactors *cusparseTriFactors =
(Mat_SeqAIJCUSPARSETriFactors*)A->spptr;
+ GPU_Matrix_Ifc* cusparseMatLo =
(GPU_Matrix_Ifc*)cusparseTriFactors->loTriFactorPtr;
+ GPU_Matrix_Ifc* cusparseMatUp =
(GPU_Matrix_Ifc*)cusparseTriFactors->upTriFactorPtr;
+ cusparseStatus_t stat;
+ PetscFunctionBegin;
+ stat = cusparseMatLo->initializeCusparseMat(MAT_cusparseHandle,
PetscErrorCode MatSolveTranspose_SeqAIJCUSPARSE(Mat A,Vec bb,Vec xx)
+ Mat_SeqAIJ *a = (Mat_SeqAIJ*)A->data;
+ PetscErrorCode ierr;
+ CUSPARRAY *xGPU=PETSC_NULL, *bGPU;
+ GPU_Matrix_Ifc *cusparseMatLo =
+ GPU_Matrix_Ifc *cusparseMatUp =
+ CUSPARRAY * tempGPU = (CUSPARRAY*) cusparseTriFactors->tempvec;
+ /* Analyze the matrix ... on the fly */
+ ierr = MatSeqAIJCUSPARSEAnalyzeTransposeForSolve(A);CHKERRQ(ierr);
Is this a memory leak on repeat solves? In any case, shouldn't this be done
once rather than every time MatSolveTranspose() is called? Same story with
repeat calls to MatSeqAIJCUSPARSEGenerateTransposeForMult?
+ ierr = VecCUSPGetArrayRead(xin,&xarray);CHKERRQ(ierr);
+#if defined(PETSC_USE_COMPLEX)
+ thrust::transform(xarray->begin(), xarray->end(), xarray->begin(),
conjugate());
+#endif
+ ierr = VecCUSPRestoreArrayRead(xin,&xarray);CHKERRQ(ierr);
WAT? The *Read* accessor returns a non-const pointer and you're using it to
modify the data? Oh the humanity.
On Tue, Jan 1, 2013 at 2:20 PM, Paul Mullowney <paulm at txcorp.com> wrote:
> Hi,
> Here's a patch for running BiCG on GPUs (with ILU(0)) preconditioners on
> GPUs for the aijcusparse.cu class. I needed to add
> (1) a VecConjugate implementation in veccusp.cu
> (2) various methods in aijcusparse.cu for building the transpose matrices
> for MatSolveTranspose* methods. The implementation of the solves is done
> under the hood in the txpetscgpu library.
> Everything builds and runs fine on my end. Let me know if this ok to push.
> Also, do patches like this go to petsc-maint or petsc-dev?
> Thanks,
> -Paul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130104/b770c76c/attachment.html>
