[petsc-dev] Fortran stubs
Jed Brown
jedbrown at mcs.anl.gov
Fri Dec 20 13:20:26 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> On Dec 19, 2013, at 1:52 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> is there a good reason not to add rules for all the fortran stubs
>> with the right dependencies, and call bfort individually?
> Can all the generated files also go in ${PETSC_ARCH} instead of
> within the source code so that I can have different branches with
> different arches and switch between them without having to
> regenerate (and remove) the fortran stubs appropriate for that
> particular arch — branch.
I would greatly prefer both of these, but I don't know how hard it is to
add to bfort. I think the dependency rules are not complicated for the
ftn-auto stubs, though f90 interfaces seem messy.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131220/ecb23bed/attachment.sig>
