[petsc-dev] Fortran stubs
Thu Dec 19 20:35:12 CST 2013
On Dec 19, 2013, at 5:44 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 19 Dec 2013, Barry Smith wrote:
>> On Dec 19, 2013, at 1:52 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> is there a good reason not to add rules for all the fortran stubs with the right dependencies, and call bfort individually?
>>   Can all the generated files also go in ${PETSC_ARCH} instead of within the source code so that I can have different branches with different arches and switch between them without having to regenerate (and remove) the fortran stubs appropriate for that particular arch — branch.
> One issue is distributing and compiling sowing.
> For ex: on windows it currently builds with g++ [not MS C]. And on big
> machines [and batch systems] we don't want to be building it with
> mpicc.
   Valid point. Perhaps they compiled stubs could be included somewhere in the tar ball and copied over to the PETSC_ARCH directory when using the tar ball and only generated when using git.
   Barry
> Satish
