[petsc-dev] BG hang still broken in petsc-maint!
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Dec 18 16:52:32 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> I forced reading in ~/.petscrc by using 'runjob --env-all' and ran the
> following runs in a loop [50*3 = 150 runs?] with the basic petsc
> example src/sys/examples/tutorials/ex1.c - and there was no hang in
> the whole session.
We should attempt to reproduce under the same conditions as Derek is
running.  Derek, can you give instructions?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131218/b283e6f9/attachment.sig>
