[petsc-dev] BG hang still broken in petsc-maint!
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Dec 18 13:35:41 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>> The relavent commits are in maint (and petsc-3.4.3) - so I'm not sure
>> what the issue is.
>    The issue is that the “commits” in maint don’t work?  Please try a build with maint ….
I believe we have worked around everything we can.  The outstanding
issue is that successive calls to MPI_Bcast (perhaps other collectives)
can cross paths.  They tested inserting MPI_Barrier between calls to
MPI_Bcast, but that was not enough either.  IBM needs to get their act
in gear.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131218/0eb39fba/attachment.sig>
