[petsc-dev] unable to merge into next from a branch from master
Matthew Knepley
knepley at gmail.com
Tue Dec 17 08:28:21 CST 2013
On Tue, Dec 17, 2013 at 8:25 AM, Peter Brune <prbrune at gmail.com> wrote:
> OK, it's completely ludicrous that this isn't fixed. Matt, you have this
> series of changesets
I am fucking traveling. I will fix it when I come home tonight.
As the changeset comments read, I was fixing a bad rebase. The changesets
were dropped from
a branch, but had been in master for a long time. I was just merging them
to master as we do
for all branches we want in.
I do not understand why the merge to master had problem with next, but it
will be simple to fix
when I am on the bus tonight.
Matt
> 69d8a9c DMPlex: More fixup from bad rebase, moved to
> DMGet/SetCoordinateSection()
> e8abe2d DM: Added DMGet/SetCoordinateSection()
> d7a12f9 Fuckup: Fix for merge that is still untangling bad rebase from
> Oct. 17th 2013 - Fixed const in declarations - Fixed merge from PetscFE -
> Fixed 2 mallocs
> e1648df replace all echo in test/tutorial makefiles with printf since echo
> behaves differently on different systems
> bb619f4 DMDA: Missing header - Damn rebase
> 6de54ef DMPlex ex3: Added 2D Q_1 and 3D P_2 tests
> 9a800dd DMDA: Added DMDAProjectFunction() and DMDAComputeL2Diff()
> 3bfb4c2 DMDA: Fixed 2D geometry - Should reuse DMPlex routines
> 32638f2 DMDA: Fix bug in 2D closure operation for cells
> a1ac9ad DMDA: Make closure operations also return the size
> affa55c DMDA: Changed DMDACreateSection() to emulate DMPlexCreateSection()
> 3385ff7 DMDA: Added functions which emulate DMPlex functionality
> 3582350 DMDA: Now DMDAGetNumCells() returns the cells in each direction as
> well
> that probably shouldn't be in 'master'. They conflict with
> https://bitbucket.org/petsc/petsc/commits/branch/knepley/feature-dmda-section
> and potentially other stuff in 'next'. What's with all the working
> directly on 'master' we're seeing now?
> - Peter
> On Mon, Dec 16, 2013 at 12:56 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sun, Dec 15, 2013 at 9:23 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Matt,
>>> Is master ahead of next on some code now? I tried to merge a tiny
>>> change on a branch I just made off of master into next and got this:
>> Okay, I will fix it. It may take me until tonight since I am in Madison
>> at a meeting.
>> I am not sure why Git cannot do this merge, but it should be easy.
>> Matt
>>> ~/Src/petsc next $ git merge
>>> barry/compressed-coloring-only-for-square-matrices
>>> Auto-merging src/dm/impls/plex/plexrefine.c
>>> CONFLICT (content): Merge conflict in src/dm/impls/plex/plexrefine.c
>>> Auto-merging src/dm/impls/plex/plexgeometry.c
>>> CONFLICT (content): Merge conflict in src/dm/impls/plex/plexgeometry.c
>>> Auto-merging src/dm/impls/da/dalocal.c
>>> CONFLICT (content): Merge conflict in src/dm/impls/da/dalocal.c
>>> Auto-merging src/dm/impls/da/dageometry.c
>>> CONFLICT (content): Merge conflict in src/dm/impls/da/dageometry.c
>>> Auto-merging src/dm/dt/interface/dtfe.c
>>> CONFLICT (content): Merge conflict in src/dm/dt/interface/dtfe.c
>>> Auto-merging include/petscdmda.h
>>> CONFLICT (content): Merge conflict in include/petscdmda.h
>>> Auto-merging config/builder.py
>>> CONFLICT (content): Merge conflict in config/builder.py
>>> Automatic merge failed; fix conflicts and then commit the result.
>>> ~/Src/petsc next|MERGING $ git merge —abort
>>> Until this is resolved no one can put new things into next
>>> Thanks
>>> Barry
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131217/0ba595b9/attachment.html>
