[petsc-dev] DMViewFromOptions()
Matthew Knepley
knepley at gmail.com
Sun Dec 15 10:17:19 CST 2013
On Sun, Dec 15, 2013 at 8:54 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Matt,
> WHEN do you want the viewing to be done? That is where the
> DMViewFromOptions() should be called, and you should move it there. Surely
> you don’t wish to view the DM in DMSetFromOptions() where presumably
> nothing is setup? Note that in analogy, MatViewFromOptions() is called in
> MatAssemblyEnd().
> Since we are going to allow XXXViewFromOptions() to be turned off with
> a master switch for performance, we can just put it were we want it and
> don’t need to call it one place and then use the resulting viewer somewhere
> else.
For now, I would like to remove it from DMSetUp() where it has no meaning,
and just make the user put it in manually.
Is that alright?
Matt
> Barry
> On Dec 14, 2013, at 11:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > The move to DMSetUp() has broken every DMPlex test. The full mesh
> > is usually not constructed at DMSetUp(), which just allocates memory.
> > This is analogous to MatSetUp(), for which we do not expect values to
> > be set.
> > I don't think the ViewFromOptions call makes sense in DMSetUp() and
> > think it should be moved back to SetFromOptions.
> > Matt
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131215/2d51c7ba/attachment.html>
