[petsc-dev] [tao-comments #191525] PetscNewLog signature change
    Satish Balay
    balay at mcs.anl.gov
    Fri Dec 13 15:23:21 CST 2013
On Fri, 13 Dec 2013, Satish Balay wrote:
> On Fri, 13 Dec 2013, Geoffrey Irving wrote:
> > On Fri, Dec 13, 2013 at 11:49 AM, Geoffrey Irving <irving at naml.us> wrote:
> > > On Thu, Dec 12, 2013 at 2:06 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > >> On Thu, 12 Dec 2013, Lisandro Dalcin wrote:
> > >>> On 12 December 2013 18:03, Todd Munson <tmunson at mcs.anl.gov> wrote:
> > >>> > The idea is to distribute TAO with PETSc and treat it like any other set of PETSc solves.
> > >>> > All the TaoLog (or TaoNewLog) macros should go away in my opinion and be replace with
> > >>> > the correct PETSc equivalents.
> > >>> > Jason?
> > >>> > Todd.
> > >>> Not sure if you guys care about previous PETSc releases, but #define
> > >>> TaoNew[Log] would ease supporting petsc-3.4 in the next TAO release.
> > >> There won't be a next [standalone] tao release. It will be part of
> > >> petsc-3.5.
> > >> And I'm not sure if maintaining a separate tao_version.h makes sense.
> > >> And there will be a minimal changing of adapting the makefiles to to
> > >> this new mode [if one needs to maintain comatibility with
> > >> both petsc-3.4+tao-2.2 and petsc-3.5/tao].
> > >> You can check the current state of this migration at 'balay/tao-to-petsc' branch.
> > > That's awesome.  To confirm: I should just merge balay/tao-to-petsc
> > > into the irving/hollow branch of petsc that I'm using to track the new
> > > features I need for my simulator development?   I.e., is that branch
> > > stable enough to track with repeated merges?
> > In order for me to use tao-to-petsc I need it to be compatible with
> > master, so I fix it for the PetscNew changes.  The updated branch is
> >     irving/tao-to-petsc
> > Hopefully that can be merged into your tao-to-petsc branch.
> I should probably rebase balay/tao-to-petsc over current master - and
> then cherrypick this patch - and push it down the stack - into the
> compile-fixes set of patches on this tree.
Ok - its rebased(to latest master)/cherry-picked(PetscLog change) and
pushed now. If anyone has balay/tao-to-petsc checked out - you should
do a 'git pull --rebase'
Satish
