[petsc-dev] getting rid of TESTEXAMPLES_XXX_XXX stuff
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Dec  6 13:53:40 CST 2013
  Jed,
    I guess you never got my earlier messages: I tried to run your test in your branch and got
~/Src/petsc  jed/tap $ make -f gmakefile  build-test
make: *** No rule to make target `arch-clang/obj-gmake/sys.test.o', needed by `arch-clang/bin/sys.test'.  Stop.
  Barry
I’d attach files but the mail system rejects them as to large for petsc-dev
On Dec 3, 2013, at 8:41 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>  Ok, there are requirements sometimes for compiling examples as well,
>>  so presumably you would need to list the requirements twice once for
>>  the runexX but also for the exX: and your compile rules would need
>>  to do the checking also ?
> Compile rules inherit variables from run rules unless we make
> requirements private (or just assign requirements directly), which we
> should probably do because run targets are usually more restrictive.
> For example, we always want to compile KSP ex10.c, even though many of
> the targets require various third-party packages.
> Now I don't mind having compile targets for each example, but for
> automated testing, I would greatly prefer to build one executable per
> package.  I pushed a branch 'jed/tap', which does this.  You should be
> able to run "make -f gmakefile -j4 build-test".  I'll rebase this branch
> before doing more work in it.
>>   Can we have “built in” rules for .F, .cxx, .cu so we don’t have to
>>   list require fc for each fortran example etc?
> Yeah.
>>   Also what about a “built in” rule for mpiexec -n n > 1 so we don’t
>>   have to put a requirement of MPI for each parallel test?
> I'm not wild about this.  Instead of inlining complicated shell script
> and losing return codes, I'd rather have a runner script that runs the
> job, captures both stdout and stderr, checks for correctness, and logs
> results.
>>   This sounds much better than the current model, the less redundant
>>   REQUIRE we need to list the better.
> Your idea of including test definitions in the source files is also viable.
