[petsc-dev] getting rid of TESTEXAMPLES_XXX_XXX stuff
Jed Brown
jedbrown at mcs.anl.gov
Tue Dec 3 08:41:59 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> Ok, there are requirements sometimes for compiling examples as well,
> so presumably you would need to list the requirements twice once for
> the runexX but also for the exX: and your compile rules would need
> to do the checking also ?
Compile rules inherit variables from run rules unless we make
requirements private (or just assign requirements directly), which we
should probably do because run targets are usually more restrictive.
For example, we always want to compile KSP ex10.c, even though many of
the targets require various third-party packages.
Now I don't mind having compile targets for each example, but for
automated testing, I would greatly prefer to build one executable per
package. I pushed a branch 'jed/tap', which does this. You should be
able to run "make -f gmakefile -j4 build-test". I'll rebase this branch
before doing more work in it.
> Can we have “built in” rules for .F, .cxx, .cu so we don’t have to
> list require fc for each fortran example etc?
Yeah.
> Also what about a “built in” rule for mpiexec -n n > 1 so we don’t
> have to put a requirement of MPI for each parallel test?
I'm not wild about this. Instead of inlining complicated shell script
and losing return codes, I'd rather have a runner script that runs the
job, captures both stdout and stderr, checks for correctness, and logs
results.
> This sounds much better than the current model, the less redundant
> REQUIRE we need to list the better.
Your idea of including test definitions in the source files is also viable.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131203/0860cf5c/attachment.sig>
