[petsc-dev] 2D finite elements in 3D ambient space
Wed Dec 4 18:22:25 CST 2013
On Mon, Dec 2, 2013 at 8:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 2, 2013 at 8:31 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>> [added context]
>> >>>> Unfortunately, something more is required for higher order accuracy,
>> >>>> since naively the coordinate section itself would have to be higher
>> >>>> order, and this would require lots of changes (the equivalent of
>> >>>> DMPlexComputeCellGeometry would be called once per quadrature point
>> >>>> instead of once per element).
>> >>> I have never been convinced that isoperimetric stuff produces enough
>> benefit
>> >>> for its complication. Polynomials are not good approximators for the
>> >>> Jacobian of these transforms. NURBS are so much better.
>> >> The value of NURBS is that (a) some coordinate transformations can be
>> >> represented exactly and (b) for certain problems, the rest solution can
>> >> be represented exactly in the ansatz space.  Quadrature error does not
>> >> magically vanish.
>> > My point is that trying to resolve particular geometry with polynomials
>> is
>> > very slowly convergent. NURBS are much better. It depends on how
>> > complicated your geometry is.
>> I thought you were objecting to "the equivalent of
>> instead of once per element".  If you were in fact agreeing with this,
>> and the talk of NURBS was just a tangent, then we are now on the same
>> page.
> I am agreeing with that. I just hate isoperimetric. Its terrible at really
> resolving geometry.
This is called "nonaffine" in PetscFE. I just merged it to next.
   Matt
>    Matt
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131204/ada2e5b0/attachment.html>
