[petsc-dev] 2D finite elements in 3D ambient space
Matthew Knepley
knepley at gmail.com
Mon Dec 2 19:44:08 CST 2013
On Mon, Dec 2, 2013 at 6:49 PM, Geoffrey Irving <irving at naml.us> wrote:
> What would be the best way to represent the rest shape of a shell (2D
> manifold embedded in 3D) in the case that the mesh has no natural 2D
> atlas? The simplest example is a sphere. I would like to give DMPlex
> the ambient 3D coordinates so as to avoid singularities in the
> gradient fields.
As long as the elements do not take up a significant portion of the sphere,
the regular thing is fine here.
> If I was only dealing with first order elements, presumably the
> correct approach would be to set the topological dimension of the
> DMPlex to 2, give it a 3D coordinate section, and fix the few places
> required to carry through gradient information correctly. I haven't
> done a thorough search of missing places yet, but at least
> DMPlexComputeLineGeometry_Internal doesn't handle 1D elements in 3D,
> which is required at the boundary of 2D shells in 3D.
Yes, this can be fixed.
> Unfortunately, something more is required for higher order accuracy,
> since naively the coordinate section itself would have to be higher
> order, and this would require lots of changes (the equivalent of
> DMPlexComputeCellGeometry would be called once per quadrature point
> instead of once per element).
I have never been convinced that isoperimetric stuff produces enough benefit
for its complication. Polynomials are not good approximators for the
Jacobian
of these transforms. NURBS are so much better. If I could not refine my way
out of the problem, I would seriously consider them.
Matt
> Is there a better clean way to support FE PDEs on spheres or other
> nontrivial surfaces in 3D?
> Thanks,
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/d872cb22/attachment.html>
