[petsc-dev] access to finite element second derivatives
Mon Dec 2 16:57:14 CST 2013
On Mon, Dec 2, 2013 at 4:49 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > So these elements are C1? I would have a tendency to fall back on mixed
> > formulations or interior penalty (I don't understand these) formulations
> for
> > this. Then C0 elements are alright.
> C^1 elements can be delicate beasts, though they wouldn't be hard to
> express now.  Second derivatives would be useful even for C^0 elements,
> to evaluate some error estimators and to provide stabilization terms
> like SUPG (with high-order elements).
> I have always disliked having separate tiny functions for each of the
> entries.  Once you add second derivatives, it is painfully obvious that
> humans will not be coding all those tiny functions, at which point it is
> clearly not the right interface.
I do not find this argument convincing, and I don't think its coherent
above.
Are you proposing to merge f0/f1/f2? That seems untenable since we must
test against different things, unless you want one fat functions with
f0/f1/f2
as arguments. That does not seem any simpler to me. If you mean you do not
want separate functions by field, I also do not agree. The indexing between
fields can get very ugly inside, and we have no good user support for that.
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/fabf63cf/attachment.html>
