[petsc-dev] access to finite element second derivatives
    Matthew Knepley
    knepley at gmail.com
    Mon Dec  2 16:09:27 CST 2013
On Mon, Dec 2, 2013 at 4:02 PM, Geoffrey Irving <irving at naml.us> wrote:
> For simulations of bending shells, I'm going to need access to second
> derivatives of both primal and dual basis functions.  This means
> versions of f0,f1 that take second derivatives, plus f2 for inner
> products with the dual second derivatives.
> Have you thought about how to fit this into the current code without
> interfering with speed when the second derivatives aren't required?
> It also increases the relevance of Jed's note that material models and
> material field evaluations might ideally be shared across evaluations
> at the same quadrature point.  I.e., merging f1 and f2 into a single
> call might avoid redundancy.
> I haven't used actual shell elements before (all the bending
> simulations I've done used ad-hoc hinge forces), so any advice about
> element choice would be great.  Are the default quadratic elements a
> good choice?
So these elements are C1? I would have a tendency to fall back on mixed
formulations or interior penalty (I don't understand these) formulations for
this. Then C0 elements are alright.
Jed, have you used any of these?
   Matt
> Thanks,
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/aafbb4cc/attachment.html>
