[petsc-dev] [Bitbucket] Commit 67125ba: metis/parmetis: update to metis-5.1.0/parmetis-4.0.3 (petsc/petsc)
Satish Balay
balay at mcs.anl.gov
Tue Aug 27 13:28:00 CDT 2013
BTW: meits has this change between 5.0.2 and 5.1.0 - which I can revert
[as its the primary cause of this breakage]
$ git diff v5.0.2..v5.1.0 GKlib/GKlibSystem.cmake
diff --git a/GKlib/GKlibSystem.cmake b/GKlib/GKlibSystem.cmake
index 7ea5bab..3fcc291 100644
--- a/GKlib/GKlibSystem.cmake
+++ b/GKlib/GKlibSystem.cmake
@@ -33,7 +33,7 @@ if(CMAKE_COMPILER_IS_GNUCC)
set(GKlib_COPTIONS "${GKlib_COPTIONS} -fPIC")
endif(NOT MINGW)
# GCC warnings.
- set(GKlib_COPTIONS "${GKlib_COPTIONS} -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas")
+ set(GKlib_COPTIONS "${GKlib_COPTIONS} -Wall -pedantic -Wno-unused-but-set-variable -Wno-unused-variable -Wno-unknown-pragmas")
elseif(${CMAKE_C_COMPILER_ID} MATCHES "Sun")
# Sun insists on -xc99.
set(GKlib_COPTIONS "${GKlib_COPTIONS} -xc99")
On Tue, 27 Aug 2013, Satish Balay wrote:
> On Tue, 27 Aug 2013, Jed Brown wrote:
> > --- you can reply above this line ---
> > New comment on commit:
> > https://bitbucket.org/petsc/petsc/commits/67125baed9b71bdad2cf52a801605839abb603c5#comment-394762
> > Jed Brown said:
> > Stop in /usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/arch-freebsd-pkgs-opt.cc1: error: unrecognized command line option "-Wno-unused-but-set-variable"
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/build_next_arch-freebsd-pkgs-opt_wii.log
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_petsc-mini.mcs.anl.gov.log
> cd /usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/arch-freebsd-pkgs-opt/libmetis && /usr/home/balay/petsc.clone/arch-freebsd-pkgs-opt/bin/mpicc -Dmetis_EXPORTS -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-but-set-variable -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DHAVE_GETLINE -O3 -fPIC -I/usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/GKlib -I/usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/include -I/usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/libmetis/. -I/usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/arch-freebsd-pkgs-opt/include -o CMakeFiles/metis.dir/__/GKlib/b64.c.o -c /usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/GKlib/b64.c
> *** [libmetis/CMakeFiles/metis.dir/__/GKlib/b64.c.o] Error code 1
> *** [libmetis/CMakeFiles/metis.dir/all] Error code 1
> *** [all] Error code 1
> GKlib/GKlibSystem.cmake has:
> # Add compiler flags.
> if(MSVC)
> set(GKlib_COPTS "/Ox")
> set(GKlib_COPTIONS "-DWIN32 -DMSC -D_CRT_SECURE_NO_DEPRECATE -DUSE_GKREGEX")
> elseif(MINGW)
> set(GKlib_COPTS "-DUSE_GKREGEX")
> else()
> set(GKlib_COPTS "-O3")
> set(GKlib_COPTIONS "-DLINUX -D_FILE_OFFSET_BITS=64")
> endif(MSVC)
> if(CYGWIN)
> set(GKlib_COPTIONS "${GKlib_COPTIONS} -DCYGWIN")
> endif(CYGWIN)
> # GCC opts.
> set(GKlib_COPTIONS "${GKlib_COPTIONS} -std=c99 -fno-strict-aliasing")
> if(NOT MINGW)
> endif(NOT MINGW)
> # GCC warnings.
> endif(CMAKE_COMPILER_IS_GNUCC)
> Hm - don't unserstand cmake - but looks like metis/parmetis is hardcoding
> flags [based on compiler - instead of using user provided flags at configure time?
> Executing: cd /usr/home/balay/petsc.clone/externalpackages/metis-5.1.0-p1/arch-freebsd-pkgs-opt && /usr/home/balay/petsc.clone/arch-freebsd-pkgs-opt/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/usr/home/balay/petsc.clone/arch-freebsd-pkgs-opt -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH=../GKlib -DCMAKE_C_COMPILER="/usr/home/balay/petsc.clone/arch-freebsd-pkgs-opt/bin/mpicc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING=" -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O " -DSHARED=1 -DMETIS_USE_DOUBLEPRECISION=1
> Is there a way to override this stuff with 'cmake options'? [and not modify this file?]
> > (We should probably be making these links stable so that they still make sense tomorrow.)
> The stable urls are nightlylogs/archive/date. I'll have the top level
> index.html automatically redirect to the correct location - so that
> the urls [after redirect] are stable.
> Satish
> > Unwatch this commit to stop receiving email updates:
> > https://bitbucket.org/petsc/petsc/commits/67125baed9b71bdad2cf52a801605839abb603c5/unwatch/balay/225fa74abc610eecc67a3d0e44502277bf0695f1/
