[petsc-dev] MPI_UNSIGNED_LONG_LONG in mpiuni.h
Chetan Jhurani chetan.jhurani at gmail.com
Thu Apr 25 14:55:59 CDT 2013
> -----Original Message-----
> From: Satish Balay [mailto:balay at mcs.anl.gov]
> Sent: Thursday, April 25, 2013 12:35 PM
> To: Chetan Jhurani
> Cc: 'For users of the development version of PETSc'
> Subject: Re: [petsc-dev] MPI_UNSIGNED_LONG_LONG in mpiuni.h
> BTW: Which version of compiler gives error? What exact error?
VS 2012.  The first file with error is this.
src\sys\objects\mpinit.c(261) : error C2065: 'MPI_UNSIGNED_LONG_LONG' : undeclared identifier
src\sys\objects\mpinit.c(279) : error C2065: 'MPI_UNSIGNED_LONG_LONG' : undeclared identifier
src\sys\objects\mpinit.c(287) : error C2065: 'MPI_UNSIGNED_LONG_LONG' : undeclared identifier
src\sys\objects\mpinit.c(329) : error C2065: 'MPI_UNSIGNED_LONG_LONG' : undeclared identifier
src\sys\objects\mpinit.c(408) : error C2065: 'MPI_UNSIGNED_LONG_LONG' : undeclared identifier
src\sys\objects\mpinit.c(449) : error C2065: 'MPI_UNSIGNED_LONG_LONG' : undeclared identifier
Essentially, all files that use MPIU_SIZE_T see it as
MPI_UNSIGNED_LONG_LONG and give this error.
Chetan
> Satish
> On Thu, 25 Apr 2013, Chetan Jhurani wrote:
> > Hi,
> > mpiuni.h does not define MPI_UNSIGNED_LONG_LONG, which leads
> > to a problem in defining MPIU_SIZE_T here in petscsys.h.
> > #if (PETSC_SIZEOF_SIZE_T) == (PETSC_SIZEOF_INT)
> > #define MPIU_SIZE_T MPI_UNSIGNED
> > #elif  (PETSC_SIZEOF_SIZE_T) == (PETSC_SIZEOF_LONG)
> > #define MPIU_SIZE_T MPI_UNSIGNED_LONG
> > #elif  (PETSC_SIZEOF_SIZE_T) == (PETSC_SIZEOF_LONG_LONG)
> > #define MPIU_SIZE_T MPI_UNSIGNED_LONG_LONG
> > #else
> > #error "Unknown size for size_t! Send us a bugreport at petsc-maint at mcs.anl.gov"
> > #endif
> > In case this is important, I'm on windows, no mpi and can
> > send more details if needed.  I'm using a slightly older
> > version of petsc, but I see that the next branch does not
> > contain the required definition in mpiuni.h
> https://bitbucket.org/petsc/petsc/src/d93c087c991ba51c9078189a5f0b6f06a517745d/include/mpiuni/mpi.h?at
> =next
> > Chetan
