[petsc-dev] single/double precision return types in blas interface
Chetan Jhurani
chetan.jhurani at gmail.com
Tue Apr 23 12:12:31 CDT 2013
There was a discussion few months ago where the problem
of single precision f2cblas routines returning double precision
values was fixed by creating a new f2cblaslapack package.
However, the maint branch still uses f2cblaslapack-3.1.1.q.tar.gz
where the signature is wrong: doublereal sdot_ and all that.
The fix is in master, which uses f2cblaslapack-3.4.1.q.tar.gz.
Perhaps maint should be updated?
maint -
https://bitbucket.org/petsc/petsc/src/fa9e63e24d90a9e99336ca74ae004b9b5f1da8f6/config/BuildSystem/config/packages/f2cblaslapack.py?a
t=maint
master -
https://bitbucket.org/petsc/petsc/src/cee652cbe889c53a5c397ca74d3ef6fdcdf8b9eb/config/BuildSystem/config/packages/f2cblaslapack.py?a
t=master
Chetan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130423/79e25ac4/attachment.html>
