[petsc-dev] PETSc factories 101 and 102
    Jed Brown
    jedbrown at mcs.anl.gov
    Sat Sep  8 16:06:47 CDT 2012
On Sat, Sep 8, 2012 at 4:01 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I am not. The JVM is specifically designed as a stack machine. You may
> execute Java byte code
> on a register machine, but Java byte code is inferior even to GNU RTL.
Good thing Dalvik is not Java™. I don't care about not being able to run
byte code intended for Oracle's JVM on Android.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120908/df495829/attachment.html>
