[petsc-dev] PETSc factories 101 and 102
    Matthew Knepley
    knepley at gmail.com
    Sat Sep  8 16:01:08 CDT 2012
On Sat, Sep 8, 2012 at 2:45 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Sep 8, 2012 at 2:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> JVM definitely sucks (stack machine with builtin slowness), but who cares
>> about performance on these things.
> You are confusing interface with implementation. Dalvik is register-based.
I am not. The JVM is specifically designed as a stack machine. You may
execute Java byte code
on a register machine, but Java byte code is inferior even to GNU RTL.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120908/48ff79b2/attachment.html>
