[petsc-dev] Status of pthreads and OpenMP support
Shri abhyshr at mcs.anl.gov
Wed Oct 31 14:57:12 CDT 2012
John,
   Thanks. I've tested ex19 on our machine with the following configure options and I don't see any slowdown issues using 2 or more threads.
Configure options: --with-threadcomm=1 --with-pthreadclasses --with-openmp --with-debugging=0 --with-blas-lapack-dir=/soft/com/packages/intel/13/079/mkl
Using C compiler: mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O -fopenmp  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -Wall -Wno-unused-variable -Wno-unused-dummy-argument -O  -fopenmp  ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/nfs2/abhyshr/petsc-dev/opt-mode-with-mkl/include -I/nfs2/abhyshr/petsc-dev/include -I/nfs2/abhyshr/petsc-dev/include -I/nfs2/abhyshr/petsc-dev/opt-mode-with-mkl/include -I/usr/include/mpich2
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/nfs2/abhyshr/petsc-dev/opt-mode-with-mkl/lib -L/nfs2/abhyshr/petsc-dev/opt-mode-with-mkl/lib -lpetsc -lX11 -lpthread -Wl,-rpath,/soft/com/packages/intel/13/079/mkl/lib/intel64 -L/soft/com/packages/intel/13/079/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core -lgomp -lpthread -lm -L/usr/lib/gcc/x86_64-linux-gnu/4.4.7 -L/usr/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpichf90 -lgfortran -lm -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -lgfortran -lm -lquadmath -lm -ldl -lmpich -lopa -lmpl -lrt -lcr -lpthread -lgcc_s -ldl
There are no external packages and  MKL is using GNU compilers  -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core -lgomp -lpthread instead of Intel compiler that you have -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread
Shri
On Oct 31, 2012, at 1:35 PM, John Fettig wrote:
> On Wed, Oct 31, 2012 at 2:15 PM, Shri <abhyshr at mcs.anl.gov> wrote:
>> Dave,
>>   I configured PETSc with MKL on our machine and tested ex2 using the options you sent (./ex2 -pc_type jacobi -m 1000 -n 1000 -threadcomm_type pthread -threadcomm_nthreads 1). However, I  could not reproduce the problem you encountered. Using more threads did not reproduce it either. What configure options did you use?
> Shri,
> I had this problem as well, and you can read my configure options from
> the pthreads.out log summary that I attached at the beginning of this
> thread.
> Regards,
> John
