[petsc-dev] Status of pthreads and OpenMP support
    John Fettig
    john.fettig at gmail.com
    Wed Oct 31 13:35:00 CDT 2012
On Wed, Oct 31, 2012 at 2:15 PM, Shri <abhyshr at mcs.anl.gov> wrote:
> Dave,
>    I configured PETSc with MKL on our machine and tested ex2 using the options you sent (./ex2 -pc_type jacobi -m 1000 -n 1000 -threadcomm_type pthread -threadcomm_nthreads 1). However, I  could not reproduce the problem you encountered. Using more threads did not reproduce it either. What configure options did you use?
Shri,
I had this problem as well, and you can read my configure options from
the pthreads.out log summary that I attached at the beginning of this
thread.
John
