[petsc-dev] [petsc4py] Extending the Mat extension type
Matthew Knepley
knepley at gmail.com
Mon Oct 29 10:40:31 CDT 2012
On Mon, Oct 29, 2012 at 11:15 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 29 October 2012 09:46, Florian Rathgeber <florian.rathgeber at gmail.com>
> wrote:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > [Apologies if this should have gone to petsc-users instead]
> I think this list is perfectly fine for the subject of your request.
> > I'd like to extend petsc4py's Mat extension type to expose
> > MatCreateSeqAIJWithArrays and MatGetArray/MatRestoreArray to python,
> > ideally via attributes/methods directly on the extension type.
> A minor issue with MatGetArray/MatRestoreArray is to properly support
> AIJ and DENSE matrices.
Don't do this. We have changed the interface so that it is specific to the
subtypes:
http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
Matt
> > I know these shouldn't normally be used and reading this thread [1]
> > I'm assuming Lisandro doesn't currently have any plans for adding
> > either of those to petsc4py?
> I would love to add them, the only issue is that I'm not sure about
> how to support all the various sparse matrix formats.
> We could start by only supporting AIJ matrices. If you can help with
> an initial patch, I can continue to refine it.
> Are you using petsc-3.3? We can add the required support in branch
> release-3.3 of petsc4py, then make a new patch release.
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121029/93bb5993/attachment.html>
