[petsc-dev] please do not replicate PETSc object options in examples
Jed Brown
jedbrown at mcs.anl.gov
Sun Oct 21 20:38:13 CDT 2012
On Sun, Oct 21, 2012 at 8:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Also don't provide monitors that exactly duplicate built in monitors;
> for example several examples had -drawcontours that identically duplicated
> -ts_monitor_solution
> It is fine to put in unique monitors specific for the problem that are
> not the same as producible with a command line option.
There should be at least one monitor somewhere to point people to as an
example. There is a PCSHELL example that just does Jacobi, presumably
because an example of a truly custom preconditioner was considered advanced.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121021/3bf9d691/attachment.html>
