[petsc-dev] [petsc-maint #136521] petsc and openmp on mac
Matthew Knepley petsc-maint at mcs.anl.gov
Wed Oct 17 18:57:50 CDT 2012
On Wed, Oct 17, 2012 at 4:51 PM, gaddiel ouaknin
<gaddyouaknin18 at gmail.com>wrote:
> Hi,
> Petsc was installed on my computer which is a mac,
> using qt creator it gives me the following error:
> targeted os version does not support use of local thread variables...
> Now i try without success to insert the openmp flag into pestc without any
> success
> So how to successfully install petsc with the openmp flag  on mac and
> working with QT ?
I do not believe PETSc connected with QT in any way. What are you trying
to do?
If you want to use compiler flags, the relevant configure variables come up
with ./configure --help. Usually you override the optional flags
  ./configure ----COPTFLAGS="-openmp"
   Matt
> Thank you very much,
> Gaddiel
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121017/f80b6286/attachment.html>
