[petsc-dev] Fwd: code using CVODE?
Fri Oct 5 13:34:54 CDT 2012
Carol, where is the source code for the new implementation? What interface
changes are needed to use it? (Is it entirely within CVODE or is it an
entirely new interface?)
On Fri, Oct 5, 2012 at 1:31 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Carol,
> An IIT graduate student did a project on simulation of radiative surface
> balance,
> which uses cvode via petsc interface.
> His petsc code is in
> petsc-dev/src/ts/examples/tests/ex5.c
> She may use ex5.c to test her new method (petsc-sundials interface might
> need to be updated).
> Hong
> On Wed, Sep 26, 2012 at 3:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Begin forwarded message:
>> *From: *"Woodward, Carol S." <woodward6 at llnl.gov>
>> *Subject: **code using CVODE?*
>> *Date: *September 26, 2012 3:36:26 PM CDT
>> *To: *Barry Smith <bsmith at mcs.anl.gov>
>> Hi Barry,****
>> I have a collaborator, Mayya Tokman – CCed above, who has been developing
>> an ODE time integration code based on exponential integrators.  She
>> implemented her new methods using the interfaces to SUNDIALS, and is now
>> looking for candidate codes to try out her methods.  Since you guys have an
>> interface to CVODE, I thought I’d see if you have any users with a CVODE
>> integration code who may be willing to work with a collaborator to test a
>> new integrator.****
>> Let me know if you know of someone.****
>> Thanks,****
>> --Carol****
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121005/e8467ee4/attachment.html>
