[petsc-dev] Fwd: code using CVODE?
Hong Zhang hzhang at mcs.anl.gov
Fri Oct 5 13:31:24 CDT 2012
Carol,
An IIT graduate student did a project on simulation of radiative surface
balance,
which uses cvode via petsc interface.
His petsc code is in
petsc-dev/src/ts/examples/tests/ex5.c
She may use ex5.c to test her new method (petsc-sundials interface might
need to be updated).
Hong
On Wed, Sep 26, 2012 at 3:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Begin forwarded message:
> *From: *"Woodward, Carol S." <woodward6 at llnl.gov>
> *Subject: **code using CVODE?*
> *Date: *September 26, 2012 3:36:26 PM CDT
> *To: *Barry Smith <bsmith at mcs.anl.gov>
> Hi Barry,****
> I have a collaborator, Mayya Tokman – CCed above, who has been developing
> an ODE time integration code based on exponential integrators.  She
> implemented her new methods using the interfaces to SUNDIALS, and is now
> looking for candidate codes to try out her methods.  Since you guys have an
> interface to CVODE, I thought I’d see if you have any users with a CVODE
> integration code who may be willing to work with a collaborator to test a
> new integrator.****
> Let me know if you know of someone.****
> Thanks,****
> --Carol****
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121005/ce481981/attachment.html>
