[petsc-dev] Preprocessor hell: #define VecType
Jose E. Roman
jroman at dsic.upv.es
Thu Oct 4 04:02:18 CDT 2012
El 04/10/2012, a las 03:40, Satish Balay escribió:
> Which XXXType shows this problem?
> I've checked a couple and they look fine.
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecType.html
> vs
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Vec/VecType.html
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPType.html
> vs
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/KSP/KSPType.html
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSType.html
> vs
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/TS/TSType.html
> Satish
Oops. I saw the problem in SLEPc only - did not check in PETSc.
The problem is not due to changing to typedef, but because I was using /*E .. E*/ comments instead of /*J .. J*/
Fixed now. Sorry for the noise.
Jose
