[petsc-dev] Fwd: [mumps-dev] support for distributed right-hand vectors?
Jack Poulson jack.poulson at gmail.com
Tue Nov 13 13:52:07 CST 2012
Hi Alexander,
On Tue, Nov 13, 2012 at 12:53 PM, Alexander Grayver <agrayver at gfz-potsdam.de
> wrote:
> Jack,
> Thanks for the comment.
> Could you comment on or give a reference to the blow up in memory one
> observes when running general purpose direct solvers in parallel?
People tend not to publish these types of negative results.
> P.S. Does Clique support pivoting?
Not yet. It is something that I will eventually make time for, but its
importance for solving indefinite equations is somewhat overblown. It is
surprisingly easy to directly solve many time-harmonic wave equations with
a Cholesky-like LDL^T factorization. In extreme cases, one can add a small
imaginary diagonal shift, chosen in the proper direction to damp
propagating waves (this depends upon your convention for time-dependence
for any radiating boundary conditions, e.g., exp(i w t) or exp(-i w t)) and
then wrap the solves in a few iterations of GMRES(k). This is often
referred to as iterative refinement.
I will likely implement a few more high-performance triangular solve
algorithms before I add support for pivoting.
Best,
Jack
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121113/c0dda333/attachment.html>
