[petsc-dev] PetscSection
Fri Nov 9 20:40:09 CST 2012
On Fri, Nov 9, 2012 at 8:34 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > I think so. I think Matt wants still to pull "fields" in, as well as
> perhaps constraints (for BCs).
>    He is wrong, that all belongs in DMs.
I agree, though it may be reasonable to return an IS describing one field,
then be able to get the closure with respect to that IS.
> > Now where do we put the convenience interface of accessing a chunk of
> data in a Vec or array? Or does the new IS interface only give use the
> index range associated with the block and we as the caller must do the
> indexing? (I'm not opposed to the latter. It's slight clutter but removes
> more from the inner loop.)
>    Accessing from an array? Maybe
>     Accessing from a vector? Unlikely since the destroys the hierarchy of
> IS below Vec. So that part may need to be in the Vec,  maybe
> VecGetSection(vec,index tag,is,&values)
Good, that also removes dependence on VecGetArray, which I hate.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121109/be3739b8/attachment.html>
