[petsc-dev] Reminder: *every* symbol with extern linkage *must* be namespaced
Mark F. Adams
mark.adams at columbia.edu
Sat Mar 17 17:46:42 CDT 2012
On Mar 17, 2012, at 4:41 PM, Jed Brown wrote:
> On Sat, Mar 17, 2012 at 15:32, Mark F. Adams <mark.adams at columbia.edu> wrote:
> done, but it won't show up until I check in my current repo, which could be a week.
> Thanks, I suspect this will have the side-effect of making it easier for the rest of us to navigate your code. I rely on tab-completion of gtags for a lot of things, but even just having the functions names sort nicely helps.
>> I don't understand why you have this gamg_setup_events. These event names are anything but intuitive in the sense that they don't stand alone and is denormalized (which makes it non-grepable). I also don't think it makes sense for GAMG to have its own classid since it's not a new PetscObject. I suggest registering with
> I bracket code that make sense for analysis, and not necessarily at function boundaries. This is not standard so I will hide them with a private #define.
> It is hard for me to believe that these names are more meaningful to you than PC_GAMGCreateProl and similar. ;-)
> enum tag {SET1,SET2,GRAPH,GRAPH_MAT,GRAPH_FILTER,GRAPH_SQR,SET4,SET5,SET6,FIND_V,SET7,SET8,SET9,SET10,SET11,SET12,SET13,SET14,SET15,SET16,NUM_SET};
> Making the events truly match your function names is low priority in my opinion, but it would be nice eventually because it helps people navigate between a log_summary and the corresponding code.
Yes, I know its a mess but I have my priorities ... these are very fluid things anyway so I'm not worried about being super clear. When things settle down a bit I'll firm them up.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120317/8aa51c8b/attachment.html>
