[petsc-dev] Reminder: *every* symbol with extern linkage *must* be namespaced
Barry Smith
bsmith at mcs.anl.gov
Sat Mar 17 15:49:46 CDT 2012
It should be done as a --download-tetgen
I don't want that --with-gnu-copyright approach reintroduced.
Barry
On Mar 17, 2012, at 2:05 PM, Jed Brown wrote:
> On Sat, Mar 17, 2012 at 13:57, Sean Farley <sean at mcs.anl.gov> wrote:
> Matt, this really needs to be its own external package (unless you have written permission the author of tetgen?) before 3.3 is released. I don't think the license for tetgen jives with petsc's license, namely, tetgen doesn't allow commercial use (which petsc does) without contacting the author. If tetgen were an external package, then everything would be ok, I believe.
> Good point, here's the license text (emphasis added). The TetGen source has to be removed or you have to put in a configure option like the old --with-gnu-copyright-code to disable it.
> TetGen License
> The software (TetGen) is licensed under the terms of the MIT license
> with the following exceptions:
> Distribution of modified versions of this code is permissible UNDER
> THE CONDITION THAT THIS CODE AND ANY MODIFICATIONS MADE TO IT IN THE
> SAME SOURCE FILES tetgen.h AND tetgen.cxx REMAIN UNDER COPYRIGHT OF
> THE ORIGINAL AUTHOR, BOTH SOURCE AND OBJECT CODE ARE MADE FREELY
> AVAILABLE WITHOUT CHARGE, AND CLEAR NOTICE IS GIVEN OF THE
> MODIFICATIONS.
> Distribution of this code for any commercial purpose is permissible
> ONLY BY DIRECT ARRANGEMENT WITH THE COPYRIGHT OWNER.
> The full license text is reproduced below.
> This means that TetGen is no free software, but for private, research,
> and educational purposes it can be used at absolutely no cost and
> without further arrangements.
> For details, see http://tetgen.berlios.de
