[petsc-dev] Reminder: *every* symbol with extern linkage *must* be namespaced
Jed Brown
jedbrown at mcs.anl.gov
Sat Mar 17 14:05:30 CDT 2012
On Sat, Mar 17, 2012 at 13:57, Sean Farley <sean at mcs.anl.gov> wrote:
> Matt, this really needs to be its own external package (unless you have
> written permission the author of tetgen?) before 3.3 is released. I don't
> think the license for tetgen jives with petsc's license, namely, tetgen
> doesn't allow commercial use (which petsc does) without contacting the
> author. If tetgen were an external package, then everything would be ok, I
> believe.
Good point, here's the license text (emphasis added). The TetGen source has
to be removed or you have to put in a configure option like the
old --with-gnu-copyright-code to disable it.
*TetGen License*
*The software (TetGen) is licensed under the terms of the MIT license*
*with the following exceptions:*
*Distribution of modified versions of this code is permissible UNDER*
*THE CONDITION THAT THIS CODE AND ANY MODIFICATIONS MADE TO IT IN THE*
*SAME SOURCE FILES tetgen.h AND tetgen.cxx REMAIN UNDER COPYRIGHT OF*
*THE ORIGINAL AUTHOR, BOTH SOURCE AND OBJECT CODE ARE MADE FREELY*
*AVAILABLE WITHOUT CHARGE, AND CLEAR NOTICE IS GIVEN OF THE *
*MODIFICATIONS.*
*Distribution of this code for any commercial purpose is permissible*
*ONLY BY DIRECT ARRANGEMENT WITH THE COPYRIGHT OWNER.*
*The full license text is reproduced below.*
*This means that TetGen is no free software, but for private, research,*
*and educational purposes it can be used at absolutely no cost and*
*without further arrangements.*
*For details, see http://tetgen.berlios.de*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120317/773e8acd/attachment.html>
