[petsc-dev] Calls to DMCreateFieldIS missing from fieldsplit.c
Jed Brown
jedbrown at mcs.anl.gov
Fri Mar 16 12:50:10 CDT 2012
Yes, this definitely worked when it was put in and most of the time since.
I can debug now if you like.
On Fri, Mar 16, 2012 at 11:57, Jungho Lee <julee at mcs.anl.gov> wrote:
> DMCreateFieldIS, etc., in fieldsplit.c, are back in. Had anyone
> rigorously test that part of the code before it went away, though? It
> fails in the PetscFree call (line 237):
> (serial version of runex28_3)
> $ ./ex28 -da_grid_x 20 -snes_converged_reason -snes_monitor_short
> -ksp_monitor_short -problem_type 2 -snes_mf_operator -pack_dm_mat_type
> aij -pc_type fieldsplit -pc_fieldsplit_type additive
> -fieldsplit_u_ksp_type gmres -fieldsplit_k_pc_type jacobi
> 0 SNES Function norm 20.0067
> [0]PETSC ERROR: PetscTrFreeDefault() called from
> PCFieldSplitSetDefaults() line 237 in
> /Users/jungholee/projects/petsc-dev-same/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: Block at address 0x7fff5fbfa5a0 is corrupted; cannot free;
> may be block not allocated with PetscMalloc()
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Memory corruption!
> [0]PETSC ERROR: Bad location or corrupted memory!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development HG revision:
> 25d401b609b5244f31ee51f342bdb0f3d0fdb309 HG Date: Thu Mar 15 23:26:29
> 2012 -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./ex28 on a arch-c named mcswl179.mcs.anl.gov by
> jungholee Fri Mar 16 11:55:11 2012
> [0]PETSC ERROR: Libraries linked from
> /Users/jungholee/projects/petsc-dev-same/arch-c/lib
> [0]PETSC ERROR: Configure run at Fri Mar 16 00:04:21 2012
> [0]PETSC ERROR: Configure options --with-superlu_dist-dir=/opt/local
> --with-superlu-dir=/opt/local --with-hypre-dir=/opt/local
> --with-sowing-dir=/opt/local --with-c2html-dir=/opt/local
> --with-parmetis-dir=/opt/local --with-metis-dir=/opt/local
> --with-shared-libraries
> [0]PETSC ERROR:
> [0]PETSC ERROR: PetscTrFreeDefault() line 287 in
> /Users/jungholee/projects/petsc-dev-same/src/sys/memory/mtr.c
> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 237 in
> [0]PETSC ERROR: PCSetUp_FieldSplit() line 366 in
> [0]PETSC ERROR: PCSetUp() line 832 in
> /Users/jungholee/projects/petsc-dev-same/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSetUp() line 261 in
> /Users/jungholee/projects/petsc-dev-same/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: KSPSolve() line 385 in
> [0]PETSC ERROR: SNES_KSPSolve() line 4057 in
> /Users/jungholee/projects/petsc-dev-same/src/snes/interface/snes.c
> [0]PETSC ERROR: SNESSolve_LS() line 193 in
> /Users/jungholee/projects/petsc-dev-same/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: SNESSolve() line 3277 in
> [0]PETSC ERROR: main() line 432 in src/snes/examples/tutorials/ex28.c
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
> On Thu, Mar 15, 2012 at 1:13 PM, Dmitry Karpeev <karpeev at mcs.anl.gov>
> wrote:
> > Okay, thanks.
> > Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120316/899f868c/attachment.html>
