[petsc-dev] Calls to DMCreateFieldIS missing from fieldsplit.c
Jungho Lee
julee at mcs.anl.gov
Fri Mar 16 11:57:23 CDT 2012
DMCreateFieldIS, etc., in fieldsplit.c, are back in. Had anyone
rigorously test that part of the code before it went away, though? It
fails in the PetscFree call (line 237):
(serial version of runex28_3)
$ ./ex28 -da_grid_x 20 -snes_converged_reason -snes_monitor_short
-ksp_monitor_short -problem_type 2 -snes_mf_operator -pack_dm_mat_type
aij -pc_type fieldsplit -pc_fieldsplit_type additive
-fieldsplit_u_ksp_type gmres -fieldsplit_k_pc_type jacobi
0 SNES Function norm 20.0067
[0]PETSC ERROR: PetscTrFreeDefault() called from
PCFieldSplitSetDefaults() line 237 in
/Users/jungholee/projects/petsc-dev-same/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: Block at address 0x7fff5fbfa5a0 is corrupted; cannot free;
may be block not allocated with PetscMalloc()
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Memory corruption!
[0]PETSC ERROR: Bad location or corrupted memory!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
25d401b609b5244f31ee51f342bdb0f3d0fdb309 HG Date: Thu Mar 15 23:26:29
2012 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex28 on a arch-c named mcswl179.mcs.anl.gov by
jungholee Fri Mar 16 11:55:11 2012
[0]PETSC ERROR: Libraries linked from
/Users/jungholee/projects/petsc-dev-same/arch-c/lib
[0]PETSC ERROR: Configure run at Fri Mar 16 00:04:21 2012
[0]PETSC ERROR: Configure options --with-superlu_dist-dir=/opt/local
--with-superlu-dir=/opt/local --with-hypre-dir=/opt/local
--with-sowing-dir=/opt/local --with-c2html-dir=/opt/local
--with-parmetis-dir=/opt/local --with-metis-dir=/opt/local
--with-shared-libraries
[0]PETSC ERROR:
[0]PETSC ERROR: PetscTrFreeDefault() line 287 in
/Users/jungholee/projects/petsc-dev-same/src/sys/memory/mtr.c
[0]PETSC ERROR: PCFieldSplitSetDefaults() line 237 in
[0]PETSC ERROR: PCSetUp_FieldSplit() line 366 in
[0]PETSC ERROR: PCSetUp() line 832 in
/Users/jungholee/projects/petsc-dev-same/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSetUp() line 261 in
/Users/jungholee/projects/petsc-dev-same/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: KSPSolve() line 385 in
[0]PETSC ERROR: SNES_KSPSolve() line 4057 in
/Users/jungholee/projects/petsc-dev-same/src/snes/interface/snes.c
[0]PETSC ERROR: SNESSolve_LS() line 193 in
/Users/jungholee/projects/petsc-dev-same/src/snes/impls/ls/ls.c
[0]PETSC ERROR: SNESSolve() line 3277 in
[0]PETSC ERROR: main() line 432 in src/snes/examples/tutorials/ex28.c
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
On Thu, Mar 15, 2012 at 1:13 PM, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> Okay, thanks.
> Dmitry.
