[petsc-dev] petsc release soon
Matthew Knepley
knepley at gmail.com
Tue Mar 13 09:08:33 CDT 2012
This looks broken:
virsaug.c: In function 'SNESSolveVI_SS':
virsaug.c:784: error:
'struct _SNESOps' has no member named 'computefunction'
virsaug.c:785: error: 'struct _SNESOps' has no
virsaug.c:807: error: 'struct _SNESOps' has no member named
'computefunction'
virsaug.c:828: error: 'struct _SNESOps' has no member named
'computefunction'
virsaug.c:883: error: 'struct _SNESOps' has no member named
'computefunction'
virsaug.c:916: error: 'struct _SNESOps' has no member named
'computefunction'
('ERROR: Missing object file',
'virsaug.o')
Am I missing something?
Matt
On Tue, Mar 13, 2012 at 8:47 AM, Stefano Zampini
<stefano.zampini at gmail.com>wrote:
> The same test should be used to run also other MATIS based preconditioners
> as PCNN. I think PCNN is broken into petsc-dev (it doesn't preallocate for
> coarse matrix if I remember well)
> Regarding roughness/portability of PCBDDC: please let me know which parts
> of code should I improve so I can put them in my todo list.
> 2012/3/13 Jed Brown <jedbrown at mcs.anl.gov>
>> The code is still pretty rough/not entirely portable, so I don't think we
>> will turn it on by default. Having a runable example is important. If you
>> want to get it ready, I would try to do it in the next week or so.
>> On Mar 13, 2012 8:15 AM, "Stefano Zampini" <stefano.zampini at gmail.com>
>> wrote:
>>> Are you planning to include pcbddc in the next release?
>>> It works, but some parts of PCBDDC code are not fully developed as we
>>> decided with Jed (primarly, the MatPartitioning procedure for multilevel).
>>> In case you want to include it into the next release, how many days I
>>> have to work on the code until the release ?
>>> 2012/3/12 Jed Brown <jedbrown at mcs.anl.gov>
>>>> On Mon, Mar 12, 2012 at 14:40, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>> I still like including the private in the name since it makes clear
>>>>> they are private include files.
>>>> Cool, glad that's out of the way.
>>>> Now about namespacing all the variables in the makefiles. This is an
>>>> opportunity to clarify/normalize variable names. I don't know what
>>>> SL_LINKER is, for example.
>>>> Also, should there be an "exported" version that makes some of the
>>>> PETSC symbols public? (I think so, even just for internal use, because I
>>>> don't want to type ${PETSC_MPIEXEC}, ${PETSC_DIFF}, ${PETSC_PYTHON}, etc in
>>>> all the makefiles.)
>>> Stefano
> Stefano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120313/a62d4328/attachment.html>
