[petsc-dev] LSC question
Jed Brown
jedbrown at mcs.anl.gov
Fri Mar 9 11:34:53 CST 2012
On Fri, Mar 9, 2012 at 11:05, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Here is the problem. We cannot use LSC with user provided L (and Lp)
> and PCFIELDSPLIT now AT ALL!! That sucks, maybe we shouldn't be looking
> for a perfect solution but for now just one that works somewhat!
Yup, this is why I still have hacks that implement MatGetSubMatrix() to
pass this stuff around. I'll follow your suggestion here. How urgent is
this?
> I will suggest the following approach. Attach various L to the original
> Jacobian with a different name for each. In your case L_displacement and
> L_pressure, have PCFIELDSPLIT propagate them to the Schur matrix. Then
> have -prefixfromfieldsplit_pc_type lsc -prefixfromfieldplit_lsc_name
> L_displacement to tell LSC which one to use.
> Barry
> Not perfect since the user could name the wrong lsc for the Schur index
> sets used but it is better than nothing.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120309/045e2f01/attachment.html>
