[petsc-dev] MatCopy to zero preallocated matrix
Jed Brown
jedbrown at mcs.anl.gov
Thu Mar 1 17:43:15 CST 2012
On Thu, Mar 1, 2012 at 17:39, Vaclav Hapla <vaclav.hapla at vsb.cz> wrote:
> OK, but:
> 1. I don't understand what's the use case for MatCopy.
Copy to a complete matrix with same or different preallocation.
> 2. I think it's not good that I can't do the thing without reallocations
> though I have an apriori information where the new nonzeros will lie.
> 3. Documentation of MatAssemblyBegin/End should definitely contain the
> information about the zero filter.
There is no "zero filter". If you preallocate and set columns (inserting
explicit zeros or whatever), they will not get filtered out.
> But OK, 2. is not a problem in my case :-)
> Thank you,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120301/1dda3ff4/attachment.html>
