[petsc-dev] clique
Jed Brown
jedbrown at mcs.anl.gov
Fri Aug 31 14:28:24 CDT 2012
Jack, this bundling strategy is a distribution nightmare. Suppose that some
other package "X" independent of clique also bundles Elemental. How does an
application (or another library) use both X and clique?
On Aug 31, 2012 1:49 PM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> Should have cc:d to petsc-dev
> context:
> clique packages metis,parmetis,elemental sources in a single bundle.
> So we were attempting to build them separately [from petsc configure].
> Jack has extensions to metis and parmetis functionality - thats used
> in clique. We tried to split this out into separate -lparmetis-addons
> library [using parmetis public includes] so that our current
> -lparmetis could be used. But this doesn't work as it needs parmetis
> private includes.
> So looks like we'll have to add these extensions to the metis/parmetis
> tarballs we distribute [and have common metis/parmetis sources
> available for both petsc an clique]
> Satish
> > > On Fri, 31 Aug 2012, Jack Poulson wrote:
> > > > > Also does clique also build elemental? Can we split it up aswell
> with
> > > > > MANUAL_ELEMENTAL, ELEMENTAL_INCLUDE_DIR, ELEMENTAL_LIBS options?
> > > > I will take care of all of these issues as soon as I get a chance.
> Clique
> > > > does currently build Elemental (it sits in external/elemental). If
> both
> > > > Clique and Elemental are both to be used in the same package, I
> would think
> > > > it would make sense to just install Clique and use its version of
> > > > Elemental. Is there a problem with this approach? It ensures
> compatibility.
> > > I'll have to check this - but 2 ways of building the same thing is not
> > > easy in petsc build tools. Esp when we provide --with-elemental-dir
> > > option to configure.
> > > Sure we'll have to make sure the compatible elemental,clique are
> > > installed - when both are installed by petsc [or by user]
> > Jack,
> > [I'm having to add the flag BUILD_PARMETIS=0.] But now I get:
> > cd /home/balay/spetsc/externalpackages/clique/arch-clique/src/parmetis
> && /usr/lib64/ccache/gcc -Wall -Wwrite-strings -Wno-strict-aliasing
> -Wno-unknown-pragmas -g3 -fno-inline -O0
> -I/home/balay/spetsc/externalpackages/clique/arch-clique/external/elemental/include
> -I/home/balay/soft/linux64/mpich2-1.1/include
> -I/home/balay/spetsc/arch-clique/include
> -I/home/balay/spetsc/externalpackages/clique/external/parmetis/include
> -I/home/balay/spetsc/externalpackages/clique/external/parmetis/libparmetis
> -I/home/balay/spetsc/externalpackages/clique/external/parmetis/metis/GKlib
> -I/home/balay/spetsc/externalpackages/clique/external/parmetis/metis/include
> -o CMakeFiles/parmetis-addons.dir/ParallelBisect.c.o -c
> /home/balay/spetsc/externalpackages/clique/src/parmetis/ParallelBisect.c
> /home/balay/spetsc/externalpackages/clique/src/parmetis/ParallelBisect.c:5:25:
> fatal error: parmetislib.h: No such file or directory
> > Looks like this code needs parmetis private includes. So the current
> > stratergy [of splitting into -lparmetis-addons] isn't working.
> > Perhaps we'll have to use a single patched metis/parmetis tarball for
> > both petsc and clique afterall..
> > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120831/d77c352b/attachment.html>
