[petsc-dev] clique
Satish Balay
balay at mcs.anl.gov
Fri Aug 31 13:48:59 CDT 2012
Should have cc:d to petsc-dev
context:
clique packages metis,parmetis,elemental sources in a single bundle.
So we were attempting to build them separately [from petsc configure].
Jack has extensions to metis and parmetis functionality - thats used
in clique. We tried to split this out into separate -lparmetis-addons
library [using parmetis public includes] so that our current
-lparmetis could be used. But this doesn't work as it needs parmetis
private includes.
So looks like we'll have to add these extensions to the metis/parmetis
tarballs we distribute [and have common metis/parmetis sources
available for both petsc an clique]
Satish
> > On Fri, 31 Aug 2012, Jack Poulson wrote:
> > > > Also does clique also build elemental? Can we split it up aswell with
> > > > MANUAL_ELEMENTAL, ELEMENTAL_INCLUDE_DIR, ELEMENTAL_LIBS options?
> > > I will take care of all of these issues as soon as I get a chance. Clique
> > > does currently build Elemental (it sits in external/elemental). If both
> > > Clique and Elemental are both to be used in the same package, I would think
> > > it would make sense to just install Clique and use its version of
> > > Elemental. Is there a problem with this approach? It ensures compatibility.
> > I'll have to check this - but 2 ways of building the same thing is not
> > easy in petsc build tools. Esp when we provide --with-elemental-dir
> > option to configure.
> > Sure we'll have to make sure the compatible elemental,clique are
> > installed - when both are installed by petsc [or by user]
> Jack,
> [I'm having to add the flag BUILD_PARMETIS=0.] But now I get:
> cd /home/balay/spetsc/externalpackages/clique/arch-clique/src/parmetis && /usr/lib64/ccache/gcc -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 -I/home/balay/spetsc/externalpackages/clique/arch-clique/external/elemental/include -I/home/balay/soft/linux64/mpich2-1.1/include -I/home/balay/spetsc/arch-clique/include -I/home/balay/spetsc/externalpackages/clique/external/parmetis/include -I/home/balay/spetsc/externalpackages/clique/external/parmetis/libparmetis -I/home/balay/spetsc/externalpackages/clique/external/parmetis/metis/GKlib -I/home/balay/spetsc/externalpackages/clique/external/parmetis/metis/include -o CMakeFiles/parmetis-addons.dir/ParallelBisect.c.o -c /home/balay/spetsc/externalpackages/clique/src/parmetis/ParallelBisect.c
> /home/balay/spetsc/externalpackages/clique/src/parmetis/ParallelBisect.c:5:25: fatal error: parmetislib.h: No such file or directory
> Looks like this code needs parmetis private includes. So the current
> stratergy [of splitting into -lparmetis-addons] isn't working.
> Perhaps we'll have to use a single patched metis/parmetis tarball for
> both petsc and clique afterall..
> Satish
